Displays the configured bandwidth pool settings for the specified VLAN.
| ingress | Displays configured bandwidth pool settings for incoming traffic only. |
| egress | Displays configured bandwidth pool settings for outgoing traffic only. |
| duplex | Displays configured bandwidth pool settings for traffic in both directions. |
| vlan_name | Displays configured bandwidth pool settings only for the specified VLAN. |
N/A.
This command displays the configured bandwidth pool settings for a VLAN. Values displayed include the VLAN, maximum reserveable bandwidth (both ingress and egress), and bandwidth reserved by application and by priority level.
The following command displays bandwidth pool settings and accepted bandwidth reservations for all ports:
show bandwidth pool duplex vlan vlan_1 # show bandwidth pool duplex vlan vlan_1 (mbps) Rsvd CIRBW Cmmt Cmmt CIRBW Vlan Dir Phy BE Limit Pools Total Avail ---------------------------------------------------- vlan_1 Rx 1000 0 1000 300 300 700 Tx 1000 0 1000 500 500 500 --------------------------------------------------------------- (mbps) CIRBW Available in Pool (per priority level) Appl Dir Pool 0 1 2 3 4 5 6 7 --------------------------------------------------------------- mpls Rx 300 300 300 290 290 290 290 290 290 Tx 500 500 500 491 491 491 491 491 491 (Rx)-Receive, (Tx)-Transmit (BE)-Best Effort
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
